Bike Wont Start
itstommmm
After I though I got bike sorted this happens. It was starting first kick when warm and after putting rear mudguard back on etc it wouldnt start I looked down at the kick start bolt as it had kept coming lose and it had fell out, also the washer that goes with that bolt has cracked in half and I now only have one half of the washer, could this be why it won't start?
try removing air filter top to allow more air in and have you oiled the filter ,, or dropped dirt in airbox ,,
i have removed air filter and airbox, got it started and it starts first kick after you get it started first. but after bike runs for about 5 minutes it cuts out and you cant rev it to stop cutting out
Sounds like a fuel starvation. Have you checked your fuel tank, lines for flow, float height on the carb and fuel tap.
it sounds like you are getting some fuel to the float bowl but it can not be sustained.
Plug is getting wet though
Edited by itstommmm
