Bike Cuts Out After Running For A Few Minutes
itstommmm
its fairly hard to start with throttle and wont start at all (i think) without throttle,once i get it started and it starts first kick after you get it started first. but after bike runs for about 5 minutes it cuts out and you cant rev it to stop cutting out.
Im think it could be one of the following:
stator/coils
not enough fuel or too much
not enough air or too much
none of the jets are blocked and exhaust middle box was recently de-coked. Bike has spark.
Fair bet it is the stator or HT coil even though plug sparks outside cylinder, it probably does not spark insidecylinder
To rule out fuel shortage connect a 100ml syringe to the carb with a length of clear tubing. You can then see if fuel is flowing in correctly.
i know it has fuel because plug is getting wet after lots of kicks. how do i know if its stator or ht coil
Can you borrow a coil off another bike?Does it run properly till it cuts out?W hat do you have to do to get it going after it cuts out?
no I cant and to get it started again I have to kick the sh*t out of it full throttle for a few minutes
