spalado Posted May 1, 2015 Report Share Posted May 1, 2015 Hello everybody My swing arm sherco'07 2.9 was broken. I want to know swing arm sherco '05 can fit with my 07 bike??? I can't find second hand swing arm '07. regard. Quote Link to comment Share on other sites More sharing options...
faussy Posted May 1, 2015 Report Share Posted May 1, 2015 I think an 06 and 08 will fit. An 05 im not so sure, because its the older frame. Quote Link to comment Share on other sites More sharing options...
copemech Posted May 2, 2015 Report Share Posted May 2, 2015 Not the same arm, but it may work, nothing to go on here as I doubt it has been tried. Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted May 6, 2015 Report Share Posted May 6, 2015 Elephant in the room.... Was an epic event leading up to the breakage? Sweet splatter? --Biff Quote Link to comment Share on other sites More sharing options...
steve_earle Posted May 7, 2015 Report Share Posted May 7, 2015 It should be the same at the wheel end, I have a spare one from an 02 I'm Breaking, They looked better quality on that year and polished instead of rough cast. You are welcome to try the one I have, If it fits you can leave it on for a case of fosters!!!! 1 Quote Link to comment Share on other sites More sharing options...
copemech Posted May 8, 2015 Report Share Posted May 8, 2015 At some point in there they moved the rear caliper inside the swingarm as well. Quote Link to comment Share on other sites More sharing options...
tony27 Posted May 9, 2015 Report Share Posted May 9, 2015 At some point in there they moved the rear caliper inside the swingarm as well. 02 was when the caliper shifted inboard for the 250 & 290, the 125 & 200 changed after that. Think that was when the number of spokes dropped from 36 to 32 as well Quote Link to comment Share on other sites More sharing options...
steve_earle Posted May 14, 2015 Report Share Posted May 14, 2015 02 was when the caliper shifted inboard for the 250 and 290, the 125 and 200 changed after that. Think that was when the number of spokes dropped from 36 to 32 as well Youre spot on there, In 02 the rear wheel was the 36 spoke with 4 bolt sprocket same as most bikes used up to 2011 when the external spoke rim came out. Quote Link to comment Share on other sites More sharing options...
