moleman Posted May 8, 2015 Report Share Posted May 8, 2015 I have acquired an early 125 minarelli fantic engine Upon removing the clutch cover I noticed the clutch basket has helical cut gears like a 240 I have had several of these engines apart over the years and have a couple in bits already but as far as I can recall I have only seen straight cut gears. If I take them apart I put a felt tip mark on the crank pinion and the clutch basket so they go back in the same place and hopefully don't chatter and rattle at tickover, so I am sure I would have noticed in the past So, did the early ones have helical gears ? And if so is there any other differances ? Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted May 8, 2015 Report Share Posted May 8, 2015 If I take them apart I put a felt tip mark on the crank pinion and the clutch basket so they go back in the same place and hopefully don't chatter and rattle at tickover, so I am sure I would have noticed in the past That would only work if the both have the same number of teeth? Quote Link to comment Share on other sites More sharing options...
moleman Posted May 8, 2015 Author Report Share Posted May 8, 2015 never thought to count .... I suppose if they had thought about it, when they designed it they could have done the math and made a hunting tooth ? just something I do, keep the same surfaces together (or not...) wont do no harm, the point being I remember all the others having straight cut teeth and this one is helical so, is this unusual (the helical bit, not my felt tip pen malarkey !) Quote Link to comment Share on other sites More sharing options...
