malcolm Posted May 9, 2015 Report Share Posted May 9, 2015 I need to remove the clutch cover but can't get the kickstart removed from the shaft. Does anyone know how to do this. Thanks. Quote Link to comment Share on other sites More sharing options...
jfc Posted May 9, 2015 Report Share Posted May 9, 2015 Just undo the retainining Allen bolt 3 or 4 turns and then rotate the kickstart into the starting position, the Allen bolt head should strike the kickstart arm and pull the kickstart off the tapered shaft. Quote Link to comment Share on other sites More sharing options...
malcolm Posted May 9, 2015 Author Report Share Posted May 9, 2015 Thanks jfc, that's what I thought but the end part attached to the shaft won't budge. Quote Link to comment Share on other sites More sharing options...
jfc Posted May 9, 2015 Report Share Posted May 9, 2015 If you have the Allen head protruding as you turn the kickstart away from the bike into the starting position it can't do anything but release from the shaft! Quote Link to comment Share on other sites More sharing options...
jfc Posted May 9, 2015 Report Share Posted May 9, 2015 This will help - https://m.youtube.com/watch?v=hjoj7n74G0s Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted May 9, 2015 Report Share Posted May 9, 2015 What he says Quote Link to comment Share on other sites More sharing options...
mik60ish Posted May 10, 2015 Report Share Posted May 10, 2015 They do get stuck on the spline and you might need a puller to get off, I have taken mine to motorcycle shop and the guy did it for and didn't charge me. As they usally have the right puller to do it with. Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 10, 2015 Report Share Posted May 10, 2015 mik60ish, the proper way to remove the kick starter is not by a puller. Watch the above video at about 1:50, Jim shows how incredibly easy the starter comes off the shaft without a puller even when it seems very stuck. Using the retaining bolt itself is just brilliant. All Pro bike owners have been faced with this dilemma. Quote Link to comment Share on other sites More sharing options...
malcolm easson Posted May 10, 2015 Report Share Posted May 10, 2015 Thanks all for your replies. I watched the video and tried the technique shown. Still no luck. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted May 10, 2015 Report Share Posted May 10, 2015 (edited) Maybe you should hire......... The A-TEAM! Edited May 10, 2015 by crazybond700 Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 10, 2015 Report Share Posted May 10, 2015 (edited) I`d pop the edge of the kick starter with a plastic/rubber hammer. I`ve seen many stuck, but it has to come off! By the way ,the proper way to work on a gasser clutch is with the bike on it`s side on the ground. Perfect time to give that shaft a shot of penetrating oil. Good Luck. Edited May 10, 2015 by lineaway Quote Link to comment Share on other sites More sharing options...
malcolm Posted May 11, 2015 Author Report Share Posted May 11, 2015 Thanks lineaway, tried that. It's really stuck. Quote Link to comment Share on other sites More sharing options...
mik60ish Posted May 11, 2015 Report Share Posted May 11, 2015 On 5/10/2015 at 12:01 PM, lineaway said: mik60ish, the proper way to remove the kick starter is not by a puller. Watch the above video at about 1:50, Jim shows how incredibly easy the starter comes off the shaft without a puller even when it seems very stuck. Using the retaining bolt itself is just brilliant. All Pro bike owners have been faced with this dilemma. I was trying to tell the guy what worked for me tried several times the Jim way it didn't work as they seem to get stuck solid and the puller method worked for me a couple of times on different GG bikes offered advice whether its taken is up to the original enquirer? 1 Quote Link to comment Share on other sites More sharing options...
malcolm Posted May 17, 2015 Author Report Share Posted May 17, 2015 Got it of. Had to remove the exhaust which allowed me to access to the rear of the component. I had to hit it pretty hard using a rod placed against the rear edge and heavy hammer. Thanks to all for advice. Quote Link to comment Share on other sites More sharing options...
