Chain Tension
shipdamite
Even with standard chain adjuster cams on a TY175, it is best to fit them one way when the axle is nearly at the front end of the slot, and the other way when the axle is nearly at the back end, because that way you can keep the handles/tabs away from passing rocks
Edited by feetupfun
