imexian Posted May 11, 2015 Report Share Posted May 11, 2015 Hi TC OSSA riders, Went out Saturday for quick praccy with son on TR280 all good nice and smooth power, went great, rode trial Sunday three quarters of way through, engine got very noisy, finished ok. Fired up when back, noisy, tried later today, (Monday) noisy! went round my mechanic to ask about it, seemed a lot quieter?? He said sounds good, i rode it, but not right, i can tell!! let him have a ride he agreed, says could be loose crank end nut?? anyone shed any light on this? it seems sort of rough, not as smooth as it was, course feeling?? Never felt like it would stall before, but now does?? Ideas?? Ian Quote Link to comment Share on other sites More sharing options...
breagh Posted May 11, 2015 Report Share Posted May 11, 2015 Blind guess have you checked the coolant? They don't like to run hot. Quote Link to comment Share on other sites More sharing options...
imexian Posted May 11, 2015 Author Report Share Posted May 11, 2015 Thought that, checked, full up!! Quote Link to comment Share on other sites More sharing options...
breagh Posted May 12, 2015 Report Share Posted May 12, 2015 Second guess Woodruff key? Quote Link to comment Share on other sites More sharing options...
imexian Posted May 12, 2015 Author Report Share Posted May 12, 2015 Thanks for another idea, but if key, surely it would not go at all? Quote Link to comment Share on other sites More sharing options...
imexian Posted May 12, 2015 Author Report Share Posted May 12, 2015 I also meant primary drive nut not crank nut! Quote Link to comment Share on other sites More sharing options...
breagh Posted May 12, 2015 Report Share Posted May 12, 2015 Thanks for another idea, but if key, surely it would not go at all? I think they slip and catch again,pals 300 had bother with one that's why I mentioned it. Quote Link to comment Share on other sites More sharing options...
imexian Posted May 12, 2015 Author Report Share Posted May 12, 2015 Ok, i'll give Birkett a call, see if he has any ideas, Did your mates bike feel a bit, sort of rough, vibrating, felt like it would never stall, now feels as if it could?? strange?? Quote Link to comment Share on other sites More sharing options...
manx2day Posted May 12, 2015 Report Share Posted May 12, 2015 Sounds like it could be main bearings. I had a set go on my old 2013 TR280i. Felt rough, sounded rough and down on power like it was struggling to pull and rev. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted May 12, 2015 Report Share Posted May 12, 2015 I think main bearings or big end is a fair bet. Loose nuts tend to give a more defined clack or knock rather than a rough rumble. Big end can be rough running without there being any play in it. Quote Link to comment Share on other sites More sharing options...
peterb Posted May 13, 2015 Report Share Posted May 13, 2015 Hi Ian, More info on the type of noise would help, knocking, whirring, grinding, scraping, tapping, top end, bottom end or gearbox. What seems sort of rough? Could be many things. There is only a nut on the LHS of the crankshaft that tightens up on the flywheel, if this is loose, the flywheel tends to shear the woodruff key rather quickly, as it spins on the shaft. So, not likely to be that. Has the motor/gearbox taken in water at some stage? Main bearings may have failed. Does the gearbox oil look milky? Is the clutch grinding on the outer casing? What model year is the bike. More info would help to diagnose. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
imexian Posted May 13, 2015 Author Report Share Posted May 13, 2015 Thanks for everyone's input, been to john lees, chas has listened to noise, mains was verdict straight away, not good!!! Quote Link to comment Share on other sites More sharing options...
imexian Posted May 13, 2015 Author Report Share Posted May 13, 2015 Seems strange been ok at weekend, then suddenly bang!! Quote Link to comment Share on other sites More sharing options...
gasgas249uk Posted May 13, 2015 Report Share Posted May 13, 2015 Sorry to hear this. Bearing in mind there isnt a plethora of Ossa mains going faulty ,you need to stop the dust / muck from getting in your engine better . Thats what will have caused this , unless you ran it with no 2st oil , which i doubt. Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 13, 2015 Report Share Posted May 13, 2015 Sorry to hear this. Bearing in mind there isnt a plethora of Ossa mains going faulty ,you need to stop the dust / muck from getting in your engine better . Thats what will have caused this , unless you ran it with no 2st oil , which i doubt. Think it would nip up before running the mains if no 2st oil. 1 Quote Link to comment Share on other sites More sharing options...
