Prototype Posted May 12, 2015 Report Share Posted May 12, 2015 Hi Gurus I have BSA C15 pitted forks. My friend told me to check with Industrial Hydraulic Repair company to re-chrome them . I contacted them and they said they can make new fork tube. which might be much cheaper then re-chrome. and last longer. Is it good idea to try new fork tube ? Is it possible to increase length of fork tube , Do i need to change spring or fork internal etc. I was think may be i can put some spacer on top nut and keep forks internal same ? Regards JH Quote Link to comment Share on other sites More sharing options...
faussy Posted May 12, 2015 Report Share Posted May 12, 2015 (edited) Id be surprised if they could make it, fork tubes are rather thin walled, and what grade of steel will they be using? Why do you think they would last longer?? Both are chromed are they not? Philpotts rechrome a set for 120 or 150, cant remember which, getting a company to make a one of pair cant be cheap, that include threading and/or circlip grooves... However, to answer your question, you can make the the tubes longer, but this will not increase the movement of the fork remember, just give you longer forks... Edited May 12, 2015 by faussy Quote Link to comment Share on other sites More sharing options...
dadof2 Posted May 12, 2015 Report Share Posted May 12, 2015 I have had pitted forks repaired and re-chromed and hydraulic rams re-chromed. This was quite a few years ago and I can't remember who did the work but the two processes are often quite different. Hydraulic rams spend much of their time retracted and therefore protected from the weather. Many hydraulic rams only have chrome plate which for a number of reasons is not ideal for forks. Forks should be nickel plated under the chrome to improve corrosion resistance and make flaking off less likely. Many cheap Chinese bikes omit this underplating and that is why their chrome rusts or pits so fast. Forks need an excellent finish to very close tolerance as they act as a bearing as well as needing to seal. Hydraulic rams can have much wider tolerance and rougher surface (although it still looks and feels smooth) Whether new or repaired is cheaper depends on the complexity of the machining on new tubes vs the amount of pitting on the old. I would be inclined to use a motorcycle fork specialist of long experience - web search will find a few. They will usually offer new tubes if appropriate as well as advise on lengthening etc. 1 Quote Link to comment Share on other sites More sharing options...
totalshell Posted May 13, 2015 Report Share Posted May 13, 2015 re chroming has to be cheaper than new manufacture of a whole leg.. Quote Link to comment Share on other sites More sharing options...
drake Posted May 14, 2015 Report Share Posted May 14, 2015 pitted forks is the name of the company. They do a very good job £165 that includes collection and delivery back to you They do an excellent job sales@pittedforks.co.uk Quote Link to comment Share on other sites More sharing options...
westyfield7 Posted May 21, 2015 Report Share Posted May 21, 2015 Last year I had a pair of Montesa forks re-plated for £150 here, near Mansfield, Notts.. http://www.hardchromeplating.co.uk/ Quote Link to comment Share on other sites More sharing options...
