highscore Posted May 17, 2015 Report Share Posted May 17, 2015 Hi All, My mains are a bit noisy on my 315R (2000 model year). I need a flywheel puller to do the job and can see a 4RT one on the bay for £32... http://www.ebay.co.uk/itm/FLYWHEEL-MAGNETO-PULLER-MONTESA-4RT-2005-/351312623639?pt=LH_DefaultDomain_3&hash=item51cbdd3817 Is this the same as a 315?? Cheapest 315 one I can find is £45 Discuss.... Quote Link to comment Share on other sites More sharing options...
alans Posted May 18, 2015 Report Share Posted May 18, 2015 It is easy to make a puller. All you need is a bit of steel plate and some screwed bar,nuts and washers. Quote Link to comment Share on other sites More sharing options...
guys Posted May 18, 2015 Report Share Posted May 18, 2015 (edited) When you want to do a proper job, a decent puller is better. According to the Jitsie Workshop catalog they are not the same. http://issuu.com/offroadaction/docs/ora-workshop £35 for this one: http://www.ebay.co.uk/itm/Montesa-COTA-315-FLYWHEEL-PULLER-M32-x-1-5MM-L-H-INT-THRD-/390744798974?pt=LH_DefaultDomain_3&hash=item5afa3476fe Edited May 18, 2015 by guys Quote Link to comment Share on other sites More sharing options...
highscore Posted May 18, 2015 Author Report Share Posted May 18, 2015 Cheers guys, Puller ordered. Main bearings/seals, plus piston, rings and gaskets on their way too! Anyone know the paint code for the casings? May as well tart them up while they're off . 1 Quote Link to comment Share on other sites More sharing options...
