spalado Posted May 19, 2015 Report Share Posted May 19, 2015 Hello all, I use GG txt pro 2011 280. I want to change engine oil& front fork (Marzocchi 40mm) Which Engine oil is better ? (in my area not have ATF type F) 1.Valvoline ATF dex3/mercon 2.BESCo transaxle 5w-30 (for munaul gear ISUZU pick-up) 3.Motul H-tech 100%syntetic sae 5w-30 (car engine oil) And,Front fork oil for Marzocchi 2011 in manual ( 5wt but in GG us (http://www.trialspartsusa.com/tech.html) recommend 7.5wt . Which one is better 5wt /7.5 wt ? regard Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted May 19, 2015 Report Share Posted May 19, 2015 (edited) I would put ATF in it (from those choises). I use lightgear oil from putoline myself. Maybe you can find it. For the fork oil, we cant say which is better, depends on setup, weight, what your needs are etc. Both are good, depending on what you want, thicker = more harder suspension. Edited May 19, 2015 by crazybond700 Quote Link to comment Share on other sites More sharing options...
guys Posted May 19, 2015 Report Share Posted May 19, 2015 (edited) Don't put car engine or manual gear oil in your bike. Besides ATF, GRO Gear Extreme 75W is also a very good oil and recommended by GasGas. Putoline and Elf also sell 75W light gear oil. Edited May 19, 2015 by guys Quote Link to comment Share on other sites More sharing options...
spalado Posted May 19, 2015 Author Report Share Posted May 19, 2015 How about Motul 75w-80 ??? Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted May 19, 2015 Report Share Posted May 19, 2015 Havent tried, but I think that would be better than your other 2 options (2 and 3). I would recommend Light gear oil by putoline. Where do you live? Quote Link to comment Share on other sites More sharing options...
spalado Posted May 19, 2015 Author Report Share Posted May 19, 2015 I live in Thailand. Don't have Putoline and GRO. Quote Link to comment Share on other sites More sharing options...
guys Posted May 19, 2015 Report Share Posted May 19, 2015 (edited) 75W80 oil is usually much to thick for your clutch, might cause excessive drag and bad shifting. If you cant find none of the above, I would rather go for something like Castrol Power RS 5W40, in any case a specific motorcycle oil suited for wet clutches. Can't you order oil online? Edited May 19, 2015 by guys Quote Link to comment Share on other sites More sharing options...
faussy Posted May 19, 2015 Report Share Posted May 19, 2015 (edited) GOing to disagree with the above posts. I would not put ATF anywhere near a motorbike gearbox, even less a gasgas. Your clutch might like it, but i can assure you your gears and main bearings will not! Id use light gear oil of any brand, followed by a car engine oil. For me id use options 2 or 3 and ATF as a last resort. Your limiting factor will be your clutch, if you put the 75W motyl in and your clutch still clears, go for it Edited May 19, 2015 by faussy Quote Link to comment Share on other sites More sharing options...
guys Posted May 19, 2015 Report Share Posted May 19, 2015 It wouldn't be the first time a motorcycle clutch starts slipping by using engine oils for cars. Quote Link to comment Share on other sites More sharing options...
