Engine Oil(Tranmission Oil) & Front Fork Oil
spalado
Hello  all,
      I use GG txt pro 2011 280.  I want to change engine oil& front fork (Marzocchi 40mm)
Which Engine  oil is better ? (in my area not have ATF type F)
   1.Valvoline  ATF dex3/mercon
   2.BESCo  transaxle 5w-30   (for munaul gear ISUZU pick-up)
   3.Motul  H-tech 100%syntetic  sae 5w-30  (car engine  oil)
And,Front fork oil for Marzocchi 2011 in manual ( 5wt
 but in GG us (http://www.trialspartsusa.com/tech.html)  recommend 7.5wt .
Which one is better 5wt /7.5 wt ?
regard
I would put ATF in it (from those choises). I use lightgear oil from putoline myself. Maybe you can find it.
For the fork oil, we cant say which is better, depends on setup, weight, what your needs are etc. Both are good, depending on what you want, thicker = more harder suspension.
Edited by crazybond700
Don't put car engine or manual gear oil in your bike.
Besides ATF, GRO Gear Extreme 75W is also a very good oil and recommended by GasGas.
Putoline and Elf also sell 75W light gear oil.
Edited by guys
75W80 oil is usually much to thick for your clutch, might cause excessive drag and bad shifting.
If you cant find none of the above, I would rather go for something like Castrol Power RS 5W40, in any case a specific motorcycle oil suited for wet clutches.
Can't you order oil online?
Edited by guys
GOing to disagree with the above posts. I would not put ATF anywhere near a motorbike gearbox, even less a gasgas. Your clutch might like it, but i can assure you your gears and main bearings will not! Id use light gear oil of any brand, followed by a car engine oil. For me id use options 2 or 3 and ATF as a last resort.
Your limiting factor will be your clutch, if you put the 75W motyl in and your clutch still clears, go for it
Edited by faussy
