bambam_n_chunx Posted May 23, 2015 Report Share Posted May 23, 2015 I've managed to source a new piston for my 84 jumbo from Italy, however when it's arrived the skirt is 5 mm shorter than the original. As this will affect the inlet port timing will the bike run or do I need another? The pistons are almost impossible to find. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted May 23, 2015 Report Share Posted May 23, 2015 May not run so well at low revs but will rev higher and produce more power at higher RPM. You need to calculate what the new inlet opening duration will be and look at a tuners handbook such as A G Bell to get a better idea of what the exact effect is likely to be. Also need to be sure the bottom edge of the exhaust port has adequate cover when piston is at at TDC Quote Link to comment Share on other sites More sharing options...
dan williams Posted May 24, 2015 Report Share Posted May 24, 2015 If it's a reed valve engine (I think it is) it should make no difference. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted May 24, 2015 Report Share Posted May 24, 2015 If it's a reed valve engine (I think it is) it should make no difference. Agreed regarding inlet duration, forgot that jumbo had a reed valve, my friend had an SWM a 1981 or 82, non reed valve 320 I think and it was that I had in mind. Comments regarding exhaust port still valid and unaffected by reed valve. Quote Link to comment Share on other sites More sharing options...
bambam_n_chunx Posted May 24, 2015 Author Report Share Posted May 24, 2015 Thanks for help, the exhaust port is not closed at tdc so I guess I'm returning it and starting the hunt again. Regards the reed valve, there seems to be a plate where this would go and I've read they removed it to soften power. Looking forward to riding this as it's been in bits since it came from Italy Quote Link to comment Share on other sites More sharing options...
