Gasgas Reedblock
slack
Hi all I have a GG250 07 with a Keihin carb fitted, the problem is the reed block rubber  is for the delorto and therefore to small,I have seen the adaptors for these and wonder if they are any good as they will have to be a tight fit.Do you have to sweat these on or are they just a push fit. Any answers would be helpful as this is a pain to replace when you remove it. Thanks.
