mischeif Posted September 15, 2005 Report Share Posted September 15, 2005 i require one urgently due to a fool who said he could re-build my engine, i since got my bike back, it starts but doesn't go into gear, nor does the clutch work, i managed to get into gear, but i now can't take it out of gear!!!!!!!!! cheers for any help mischief Quote Link to comment Share on other sites More sharing options...
admacp Posted September 15, 2005 Report Share Posted September 15, 2005 Go to http://www.gasgasmotos.es/web/eng/frame.htm and click on the link for trial (top left hand column)then select the bike and year in the right hand drop down box and then look for it at the bottom of the pge. It is a downloadable file in .pdf format. Quote Link to comment Share on other sites More sharing options...
gazer Posted September 16, 2005 Report Share Posted September 16, 2005 sorry chap there is no quick answer to that, looks like you got to get the engine out and start agian,engine and gear box on that model are very easy to rebuild.hope you did not pay for that Quote Link to comment Share on other sites More sharing options...
kevin j Posted September 16, 2005 Report Share Posted September 16, 2005 before you pull the engine out, take off the right side cover and check out the shifter mechanism, and clusth assembly. something was not put back in correctly. Quote Link to comment Share on other sites More sharing options...
