mirko91 Posted June 5, 2015 Report Share Posted June 5, 2015 Hello to everybody, I'm new to trials and I just bought a TXT pro 280 05 and I changed both tyres for fresh brand new xlights. I have no problems with the rear but the front tyre if I run it at 0.5-0.45bar of pressure it just comes off the bead and goes inside the rim for about 15-20cm. If I put some soapy water and pump it up to 4bar it pops on again, so I leave it for a day to set in place but after a couple of rides it goes off again. I did clean the rim etc. Any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
copemech Posted June 6, 2015 Report Share Posted June 6, 2015 Go to a tire shop and lube it up good with some REAL tire lube, then air it up high to sit overnight and try it! Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted June 6, 2015 Report Share Posted June 6, 2015 Often happens.Try to clean everything so its really dry and turning tyre so repositioning the security clamp possible to the bit which "drops" in. It may be that you need to leave it punped up (25psi?) for a week or so then it can take on the shape as it may have been stored squashed. Good luck its usually trial and error tbh. 1 Quote Link to comment Share on other sites More sharing options...
mirko91 Posted June 6, 2015 Author Report Share Posted June 6, 2015 Thanks will try that. I just ordered this stuff https://www.ajsutton.co.uk/product/unbranded/519.17.05/reifenmontagepaste%205kg,%20mont%20seal?uID=0hopefully it will stick the tyre to the rim Quote Link to comment Share on other sites More sharing options...
baldilocks Posted June 6, 2015 Report Share Posted June 6, 2015 I made an error years ago of using duct tape instead of rim tape. It works and means you dont have any problems locating the valve hole in the rim tape when you get a puncture during an event. However the tape wasn't on correctly and in places had gone across the ridge on the rim the tyre sits on. I had the problem you describe until i trimmed the tape. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted June 6, 2015 Report Share Posted June 6, 2015 I always use insulating electricians tape in the well Quote Link to comment Share on other sites More sharing options...
mirko91 Posted June 6, 2015 Author Report Share Posted June 6, 2015 I'm using the proper flap so no issues with that Quote Link to comment Share on other sites More sharing options...
baldilocks Posted June 6, 2015 Report Share Posted June 6, 2015 Yes as long as the proper tape is in the centre of the rim ? By the way is the tube the correct size ? Quote Link to comment Share on other sites More sharing options...
mirko91 Posted June 6, 2015 Author Report Share Posted June 6, 2015 Yep it is straight in the middle..the tube is a 2.75x21 so it's ok. Also the old tyre that was mounted had the exact same issue Quote Link to comment Share on other sites More sharing options...
baldilocks Posted June 6, 2015 Report Share Posted June 6, 2015 Is the rim buckled badly? Quote Link to comment Share on other sites More sharing options...
axulsuv Posted June 6, 2015 Report Share Posted June 6, 2015 A out of round rim will do that , Or a bent rim flange ... Quote Link to comment Share on other sites More sharing options...
mirko91 Posted June 6, 2015 Author Report Share Posted June 6, 2015 The rim us round without any dent at all, that's what gets me Quote Link to comment Share on other sites More sharing options...
mirko91 Posted June 6, 2015 Author Report Share Posted June 6, 2015 I'm new to trials not to bike and mechanics stuff so all is as it should except for the tyre soap that I didn't use Quote Link to comment Share on other sites More sharing options...
mirko91 Posted July 10, 2015 Author Report Share Posted July 10, 2015 Guys the proper tyre paste did the trick. Always use it! Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted July 10, 2015 Report Share Posted July 10, 2015 I showed up late here but I was going to suggest riding everything on the rear tire. glad you got it fixed. --biff 2 Quote Link to comment Share on other sites More sharing options...
