Front Tyre Coming Off Bead
mirko91
Hello to everybody, I'm new to trials and I just bought a TXT pro 280 05 and I changed both tyres for fresh brand new xlights. I have no problems with the rear but the front tyre if I run it at 0.5-0.45bar of pressure it just comes off the bead and goes inside the rim for about 15-20cm. If I put some soapy water and pump it up to 4bar it pops on again, so I leave it for a day to set in place but after a couple of rides it goes off again. I did clean the rim etc. Any ideas? Thanks
Often happens.Try to clean everything so its really dry and turning tyre so repositioning the security clamp possible to the bit which "drops" in. It may be that you need to leave it punped up (25psi?) for a week or so then it can take on the shape as it may have been stored squashed.
Good luck its usually trial and error tbh.
I made an error years ago of using duct tape instead of rim tape. It works and means you dont have any problems locating the valve hole in the rim tape when you get a puncture during an event. However the tape wasn't on correctly and in places had gone across the ridge on the rim the tyre sits on. I had the problem you describe until i trimmed the tape.
  • 1 month later...
