125Cc Fork Nuts? Oil And Capacity
martinchivers
hi guys. I'm needing to change my fork oil and fit spacers as I have an inch of sag. I Dropped front wheel out. Loosened yokes, but can't undo top screw/bolt. All the chrome bit is turning. Did back up but the whole thing is just turning. I'm f****d if I can't get the nut off. Ordered spacers. Will get oil (once I figure out the type and quantity). There's no way I can change the seals. Never done it. How can I hold the chrome bit tight to get the top bolts out? They are 32mm. Cheers!
