jools Posted September 18, 2005 Report Share Posted September 18, 2005 Hi, A mate of mine has a 4 month old '05 (UK bike), the bike has had light use, but he is having problems with it not reving out properly when he goes for big steps etc (revs like the bike is cold). he's tried jetting, adjusting the carb air screw, different oils, reeds, you name it. other than that its perfect and its a lovely bike. anyone any suggestions? has a Keihin carb conversion been done on a Scorpa? Thanks Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted September 19, 2005 Report Share Posted September 19, 2005 What color is the plug? If one doesn't solve the problem, move to the next: -- fresh plug and fresh gas and thoroughly cleaned carb and air filter. --Check for air leak at intake. --Play with the choke (enrichener)in small increments and see if the problem gets better or worse...to check jetting. Quote Link to comment Share on other sites More sharing options...
jools Posted September 19, 2005 Author Report Share Posted September 19, 2005 The plug is chocolaty brown colour, which is good. We did'nt think about an induction leek and yeah, its been run on Shell Optimax fuel. air filter, carb etc are spotless, there is not too much oil on the filter either . will check for induction leek though. would'nt the engine race if it was sucking in more air?? Thanks for the suggestion. Quote Link to comment Share on other sites More sharing options...
robee Posted September 20, 2005 Report Share Posted September 20, 2005 Sounds like mine does when I go swimming with it. If water gets through the air filter and into the carb' it can still idle around but when it is asked to rev up a bit more it can suck the bubble of water in from the bowl. You said the carb was spotless so I figure this has been already checked. Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted September 20, 2005 Report Share Posted September 20, 2005 air filter, carb etc are spotless, there is not too much oil on the filter either . will check for induction leek though. would'nt the engine race if it was sucking in more air??Thanks for the suggestion. <{POST_SNAPBACK}> Did you blow out the jets AND hold them to a light and look through them for obstructions? And, you're right...an air leak can make the engine race, but not always. Did you check the condition of the sparkplug wire? It is possible for it to have a leak that only happens at high revs. Check all your wires, too. Don't forget the kill button. Quote Link to comment Share on other sites More sharing options...
eric23 Posted September 23, 2005 Report Share Posted September 23, 2005 Check the timing? Quote Link to comment Share on other sites More sharing options...
boofont Posted September 23, 2005 Report Share Posted September 23, 2005 6 months old? Send it back under warranty, he should get 6 months from the dealer. Quote Link to comment Share on other sites More sharing options...
