Beta Rev Gear Drum
skippy1234
Break the rollers and any cage out with a screwdriver or similar.
Get a bolt (correctly called a screw as you need it threaded all the way to the head) the head of which just fits inside the bearing. Put the head into the bearing. Then you need a washer that is a larger diameter than than the inside of the lip on the bearing race. Cut the washer in half then hook the halves under the lip on the bearing housing. Tighten a nut down the threads to lock the washer halves in place. You can the pull on the bolt with slide hammer or similar.
