What Oil To Use ?
talbotvanman
I have purchased a 1980s Cota 200 There is only one drain plug ( on the gearbox side )
So do I take it the oil is common to the gearbox AND clutch/primary side ?  I have seen
various oils mentioned 10/20 10/40 etc but I have a supply of 5/30 would this be suitable
The bike will have VERY light use as I will not be competing very much !
I would try asking Sandifords (importer of Cota 200) or Nigel Birkett (Birkett Motorsport)
I only ever had 348s which had separate primary and gear oil. couple of my friends had 200s  but I can't remember what oils they used.
You are very unlikely to do any harm with 5-30 even if it is not quit right grade. I would be more worried about not changing one of the oils if 2 should be used.
