Honda Tlr 200 Problem
luke7129
Hi was wondering if anyone could shed a little light on my problem i have a 1986 honda tlr 200 relfex, the bike runs and starts fine but when it gets hot it starts to rev up on its own and they dont die off, i have tried 2 new carbs and i still have the same problem. Am i missing something? Thanks
The induction tract is under vacuum when the motor is idling, so if there is a leak, air will be getting in, causing the motor to run faster and leaner than it should.
If carby cleaner or WD40 gets sucked in through a leak, the motor will change RPM. This helps to locate the site of the leak.
