frenchmike Posted June 21, 2015 Report Share Posted June 21, 2015 Hi please can any one tell me if it is normal to re'bore a 125 cylinder that's if it can be done, and where is the best place to buy a new piston and ring etc. Quote Link to comment Share on other sites More sharing options...
goudrons Posted June 22, 2015 Report Share Posted June 22, 2015 (edited) They aren't rebored but the lining of the barrels are replated with a special coating of Nikasil chrome. First, buy a new piston kit (new base and head gasket as well), your Beta importer should have them. Then send the new piston and barrel to a specialist Nikasil cylinder plater. They aren't too many of these replaters around, most end up here http://www.langcourt.com/index.html Or their American outlet. They will remove the worn lining, replate and hone it to exactly match the piston you supplied. Edited June 22, 2015 by goudrons Quote Link to comment Share on other sites More sharing options...
