Txt 270 Or 280?
sean65
I have good results with 10w40, atleast no real problems (in several pre-pro models). But thinner could prefent sticking problems e.g. better.
If you do get problems you can just swap again, its not damaging the clutch or something.
Edited by crazybond700
Well a local rider came over and declared my bike to be a good example, with only a few minor check to do. The chain needs tightening a little and I just need to check the coolant level. I assume this is just a case of lifting the fuel tank. I may drain at some point. Otherwise he says it rides well and doesn't;t appear to have had a hard life, which is good to know. :D
