sean65 Posted July 18, 2015 Author Report Share Posted July 18, 2015 Don't seem to be able to get 5w 30 anywhere. I have some 10w 40 at home, so it's either that or the ATF. At least the brake fluid was straight forward. lol Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted July 18, 2015 Report Share Posted July 18, 2015 (edited) I have good results with 10w40, atleast no real problems (in several pre-pro models). But thinner could prefent sticking problems e.g. better. If you do get problems you can just swap again, its not damaging the clutch or something. Edited July 18, 2015 by crazybond700 Quote Link to comment Share on other sites More sharing options...
sean65 Posted July 19, 2015 Author Report Share Posted July 19, 2015 I think that's the plan. Empty out the ATF which may be old anyway, then try the 10w 40 which I have some of anyway. Well at least until I can find the 5w 30. Quote Link to comment Share on other sites More sharing options...
sean65 Posted July 20, 2015 Author Report Share Posted July 20, 2015 Well a local rider came over and declared my bike to be a good example, with only a few minor check to do. The chain needs tightening a little and I just need to check the coolant level. I assume this is just a case of lifting the fuel tank. I may drain at some point. Otherwise he says it rides well and doesn't;t appear to have had a hard life, which is good to know. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted July 21, 2015 Report Share Posted July 21, 2015 |The filler cap is uinder the tank yes. Quote Link to comment Share on other sites More sharing options...
