Inner Component, Silencer
bestrial
hello
i have a jotagas 2013 model.
Does anybody know if you can change the material of the exhaust (inner component, silencer)?
I want to try, but I am afraid that the exhaust must be cut in two pieces to do a proper job.
I would be grateful for any information.
thanks
  On 7/4/2015 at 7:42 AM, lowbrow said:
I've repacked the rear section to good effect, but you're not talking about that are you?  If you want to repack the front section of the silencer it will be a cut and shut job.
I am wanting to repack my rear section - does the centre pipe that the packing is around pull out (like my Beta did) or is it a pick and pull all the old packing out? Did not want to pull too hard on the pipe so left it alone until I found out.
yes, i talk about the frond section of the silencer....
  Quote
It's pick and pull and it's packed in there tight too.  Very long-nosed pliers are required before the perforated tube will come loose.  The tube is bent too, so no alternative but to re-insert before packing new stuff around it.
