Offensive Mid Pipe
macdaddy
I recently bought back my '00 250 rev 3.........
well to make a long story short I've been going through it.?.!..?..!....
and I've found that the mid pipe has worn a sizeable divot into the gas tank !
Has any one ever worn through the tank?
So far I've took a die grinder to the weld on the mid pipe and added some asbestos type muffler tape to the tank.
I think this will be sufficient .
Just wondering if any one else had this problem
  • 3 weeks later...
Not quite the same thing, but my mid section rubs on the bolt in the top of the clutch cover if the seat plate comes loose. Last year I had to get the tank/frame Tig welded under the petrol filler cap plastic, it had cracked down the two welds and was leaking fuel.
BB
