Keihin Carb Manifolds !
djdenzil
Does anyone know where I can purchase an airside manifold rubber for a Keihin 28mm PWK to a 290 Sherco 05 airbox!!!!
Local enquiries have drawn a blank!!!!
:rolleyes:  :D  :D
Yes the cessna engine has a really good hose which I fitted but I'm not sure of the part number. Will try to find out. Ordered it mail order and it was
ive got grimbo's 04 works 290,the one he won the schottish on,and thats got a standard air box rubber on it.what you need too do is put the standard one in hot water and then put it on the back of the carb,ok?on my son's 125 ive used a bit of subaru turbo hose,had a three mm ring made up to push on the air box.what you need too do though is leave the rubber on the carb permanant.try this and see how you get on.BIG BEN @TEAMSHERCO.COM.
SHERCO'S ARE THE BEST,WITHOUT A DOUBT. :rolleyes:
