Rev 3 Swingarm Bearing
2stroke4stroke
Hi
Ring up your local bearing supplier, ask for;
Swing arm bearings, HK2218 Roller Needle Cup Bearing
If the spacer is worn you will have to buy these from Beta
FYI, if you need swing arm bearings, i bet the bottom shock bearing is wore too
Shock bearings BLRB366748 Spherical Bearing
These are for my 2003 Rev 3, should be the same
Happy to help
Whiskey
Edited by whiskey
Thanks Whiskey, and yes I did the bottom bearing recently but had to just clash it together for a two day when cleaning them out revealed the play in the pivot bearings.  Spacers seem a bit pricey at over £8 each but fortunately I know a man with a lathe.
