Cota 200 Kickstart Shaft
29markt
Evening all,
Can anyone tell me the correct procedure or slot on the shaft for refitting the pawl gear(s) back so the tension is correct for the Kickstart to return correctly to the stop and not damage the case? Struggling a bit as far as the slot in the shaft for the kickstart bolt is not in the correct position at present after replacing the gears..bit stumped!
Thanks!
Mark
  • 2 weeks later...
Thanks Lineaway, fiddly as owt int it, had a few indicative pictures off a few people, but its hit and miss, understand the tension bit, but holding shaft in situ and getting slot to line up for kickstart bolt is a hard one, will persevere, thanks pal
