renegade master Posted July 24, 2015 Report Share Posted July 24, 2015 Hi Guys, Just a quick question, does the 2002 txt pro 280 rear shock look like this? looks to me like the bottom part is bent or is this curved for a reason? I tryed to check with the 2004 and 2007 gassers that are hee but they look different. Cheers all! 1 Quote Link to comment Share on other sites More sharing options...
eddie1 Posted July 24, 2015 Report Share Posted July 24, 2015 It should be straight. The rod is bent. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted July 24, 2015 Report Share Posted July 24, 2015 Yes looks bent Quote Link to comment Share on other sites More sharing options...
eddie1 Posted July 24, 2015 Report Share Posted July 24, 2015 This one is dirty but not bent Quote Link to comment Share on other sites More sharing options...
tony27 Posted July 24, 2015 Report Share Posted July 24, 2015 Definitely bent, had something similar on the last gas gas I owned. Was bent at the start of the thread where the mounting eye ended when done up. Would possibly be able to be straightened but you'd need access to a lathe to cut an accurate internal thread in a decent sized bar that screwed on in place of the eye & then would need to make a set of soft jaws that would fully support the rest of the shaft while you slowly apply pressure to the bar. That shock in the lower photo looks exactly like original shock out of my 05 sherco Quote Link to comment Share on other sites More sharing options...
renegade master Posted July 28, 2015 Author Report Share Posted July 28, 2015 Thanks guys! I thought as much! wonder if i take the hammer and gas tourch to it? Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted July 29, 2015 Report Share Posted July 29, 2015 THat will probably help! (for your irritation level ) 1 Quote Link to comment Share on other sites More sharing options...
renegade master Posted October 7, 2015 Author Report Share Posted October 7, 2015 Ok think im losing my mind now, I just took off my other shock now from my other pro and its the same as the photo I posted? which could mean i have a unique set of skills which enables me to bend both my gas gas txt pro 2002-2003 rear shocks to the exact same angles? on different bikes! The only reason I took off the shock tonight was it was leaking oil, like leaving small puddles on the ground, but does oil go in these shocks or is it gas? Quote Link to comment Share on other sites More sharing options...
cbutler Posted October 7, 2015 Report Share Posted October 7, 2015 Man that sucks but you are consistent It is my understanding that these shocks are not rebuildable. My 01 280 bumper went south and had to get one for a Beta split it down the middle and safety wire it. Quote Link to comment Share on other sites More sharing options...
renegade master Posted October 8, 2015 Author Report Share Posted October 8, 2015 dam! i thought all shocks were rebuildable! oh well back in it goes!!!! Quote Link to comment Share on other sites More sharing options...
renegade master Posted October 8, 2015 Author Report Share Posted October 8, 2015 oh wait! just had a quick look at splat! seems hes offering a? guess what! rear shock rebuild! (new oil plus gas refill) ! great so now iv learned that it was oil that was comming out of my rear shock! wonder is it worth 110stg for a rebuild tho? immm probbably is, as an new one is 450stg!!! http://www.splatshop.co.uk/rear-shock-rebuild.html Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted October 8, 2015 Report Share Posted October 8, 2015 (edited) There is deffinatly oil in there (or there should be). Servicing a shock is not that difficult although retrieving the parts might be. E.g for my cr250 I can just buy replacement parts easily and with some instruction(video's) its no hard job. Just stay calm, think and work clean. THe difficult part is normally setting it up right, what thichness oil? other shims? etc. And the difficulty with this shocks is that they are not really made to be opened and closed, but still than its possible. I have my TT600 shock done by a pro, he made a nipple in the shock to charge it with nitrogen, added a thicker shock and more rebound. Read carfully, spatshop will charge extra for a GG (sachs). And you need a new rod. I would look for a replacement. Simple ones are available here for around 280 euro's. Also I would try to find out why they bent like that, havent seen that before (except for you ) Edited October 8, 2015 by crazybond700 1 Quote Link to comment Share on other sites More sharing options...
renegade master Posted October 8, 2015 Author Report Share Posted October 8, 2015 Yes!!! i always knew i'd be someone famous!!! Quote Link to comment Share on other sites More sharing options...
faltenhals Posted November 19, 2015 Report Share Posted November 19, 2015 Hi. I have the same problem with the rear shock of my 1998 GasGas Contact. It leaks oil. The Suspensionservice said, that this shock is not rebuildible. has anyone an idea for an alternative solution? i don´t wont to buy a new shock for 450 bucks for a bike which has a woth of 1000... does anyone know a other shock that fits? Quote Link to comment Share on other sites More sharing options...
cbutler Posted November 19, 2015 Report Share Posted November 19, 2015 I contacted the splat shop the shock in manufactured non-rebuild. He sends it to a guy that works for Ohlens he cuts it and machines it so it can be rebuilt. seen this on ebay the bumper is worn but mine was not even there got one for a Beta split it down one side took the spring off put the new stop on used safety wire did three spots top middle and bottom been like that for six monthe or more. http://www.ebay.com/itm/GAS-GAS-TX-JTX-JT-TXT-EDITION-CONTACT-REAR-SHOCK-/231754066660?hash=item35f59e6ae4:g:JxsAAOSwvt1WSMBw Quote Link to comment Share on other sites More sharing options...
