Sherco 250 Rear Mudguard Needed
okjc250
Seeing as it's listed as discontinued you'll need to find a signwriter who will copy your original in thick vinyl, someone who does graphics for MX bikes is your best bet. I had to do similar for the seat graphic on my Jarvis until Chris at Splatshop was able to find the part numbers which aren't listed in Sherco's online parts books. If yours is in pieces you may be able to find a guard with okay sticker on ebay to copy
My suggestion to preserve your guard is run cable ties instead of the screws at the rear, they pop off quite easily & it only takes a couple of minutes to loosen the front capscrew & slide the lip back under the frame then fit new ties. Took me about 6 years to damage my first rear guard & I'd had some pretty big crashes by then including backwards off the top of a 8 foot high rock which wrecked the bars
