aldy13 Posted August 9, 2015 Report Share Posted August 9, 2015 Hi, just bought TY 250 and the castle nut on the rear wheel spindle is tightened up way past the holes for the split pin, is there a spacer between the wheel bearing dust cover and the swing arm on the sprocket side? Cheers Andy Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted September 4, 2015 Report Share Posted September 4, 2015 There is a washer on the outside of the snail cam adjusters. --biff Quote Link to comment Share on other sites More sharing options...
feetupfun Posted September 4, 2015 Report Share Posted September 4, 2015 On the sprocket side there is a spacer with a steel disc. The steel disc protects the bearing dust seal. The bearing dust seal runs on the OD of said spacer TY250 twinshock does have another spacer that sits inside the chain adjuster cam and inside the swingarm plate. If someone has fitted TY175 chain adjuster cams, your axle will appear to be too long, and the axle will be able to flop up and down in the swingarm slot when the nut is loose. If you post up a picture it should be obvious to any TY250 owner what is wrong or missing on your bike Quote Link to comment Share on other sites More sharing options...
