hamill_glen Posted August 10, 2015 Report Share Posted August 10, 2015 am just after fitting the clutch lighter the shedworks sell . After fitting it and adjusting the clutch etc I started the bike up pulled the clutch in selected first gear n slowly let the clutch out but nothing happened ?? Any ideas Quote Link to comment Share on other sites More sharing options...
4stroke Posted August 10, 2015 Report Share Posted August 10, 2015 If you have extended the operating arm your cable may not be long enough to allow for this. Take all of the adjustment out both at the lever and at the bottom end of the cable next to the cylinder. If still no good you need to extend the cable inner. (New cable) Quote Link to comment Share on other sites More sharing options...
totalshell Posted August 10, 2015 Report Share Posted August 10, 2015 you ve not adjusted the clutch properly.. Quote Link to comment Share on other sites More sharing options...
b40rt Posted August 10, 2015 Report Share Posted August 10, 2015 If you have extended the operating arm your cable may not be long enough to allow for this. Take all of the adjustment out both at the lever and at the bottom end of the cable next to the cylinder. If still no good you need to extend the cable inner. (New cable) Or carefully shorten the outer, if cable is long enough. Quote Link to comment Share on other sites More sharing options...
hamill_glen Posted August 11, 2015 Author Report Share Posted August 11, 2015 Thanks for the advise . Got it sorted thanks Quote Link to comment Share on other sites More sharing options...
