barryb1973 Posted August 10, 2015 Report Share Posted August 10, 2015 (edited) can only find lower ones for sale is top the same ,are they a special or can you get them of shelf Edited August 10, 2015 by barryb1973 Quote Link to comment Share on other sites More sharing options...
lotus54 Posted August 16, 2015 Report Share Posted August 16, 2015 You have the Ohlins? I as thinking they are just a pivot- should be able to just clean/lube. I could be wrong, I have had it off for a bit- have to. Take the exhaust head pipe to remove. Quote Link to comment Share on other sites More sharing options...
barryb1973 Posted August 17, 2015 Author Report Share Posted August 17, 2015 its a spherical bearing(ROSE JOINT)its all ok now turned out to be loose bolt Quote Link to comment Share on other sites More sharing options...
