sean65 Posted August 19, 2015 Author Report Share Posted August 19, 2015 (edited) Ok. Good information thanks. I thought the black box was a relay of some sort (shows what I know..lol) , so that is the rectifier on these. Non reparable I guess? It might be time to learn how to use a multimeter. I wouldn't know where to start to test. I do have one though. Diagram source? Gas Gas USA? Edited August 19, 2015 by sean65 Quote Link to comment Share on other sites More sharing options...
faussy Posted August 19, 2015 Report Share Posted August 19, 2015 I would first test the AC voltage on the yellow wire entering the thermostat (if this is zero then you have a bad coil) If there is current there, bypass the thermostat with your shorting wire, and test the DC voltage leaving the rectifier. Quote Link to comment Share on other sites More sharing options...
cbutler Posted August 19, 2015 Report Share Posted August 19, 2015 http://www.trialspartsusa.com/ All the gasgas info and check out his videos on YouTube Quote Link to comment Share on other sites More sharing options...
sean65 Posted August 28, 2015 Author Report Share Posted August 28, 2015 A quick check please. My new rectifier has come. This one has a white and yellow wire (as well as the red and black) whereas the previous had the 2 yellow. Is the white wire with bullet connector the earth or thermostatic switch. I really don't want to connect incorrectly and I cant seem to find a wiring diagram with the white wire shown. Quote Link to comment Share on other sites More sharing options...
sean65 Posted August 29, 2015 Author Report Share Posted August 29, 2015 Done some reading. I think white is the earth can anyone cofirm please? Quote Link to comment Share on other sites More sharing options...
cbutler Posted August 29, 2015 Report Share Posted August 29, 2015 I dont know for sure,can you contact the person you bought it from Quote Link to comment Share on other sites More sharing options...
sean65 Posted August 29, 2015 Author Report Share Posted August 29, 2015 Yes there technician not in until Tuesday so thought i would check forum Quote Link to comment Share on other sites More sharing options...
