malcolm Posted August 13, 2015 Report Share Posted August 13, 2015 Just fitted a new chain to my beta evo 125. It seems very loose even with the snail cams at their longest setting. Are chains sold at a standard length for the buyer to remove links as required or should I wait until the chain has stretched a little until I remove a link. What's the worst that can happen with a loose chain? Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted August 13, 2015 Report Share Posted August 13, 2015 (edited) Wrecked crankcases. Fit a half link. In the old days we did that when we could in order to keep the wheelbase as short as possible. Edited August 13, 2015 by 2stroke4stroke 1 Quote Link to comment Share on other sites More sharing options...
dabba Posted August 13, 2015 Report Share Posted August 13, 2015 (edited) The chain should be 100 links. Most trials chains are 102 links or more, so you'll probably need to remove links. The original Beta snail cams and the Apico ones will offer enough adjustment with 100 links, but the Jitsie ones don't allow the spindle to move forward enough for 100 links if you're using a rear sprocket over 42 teeth.. Edited August 13, 2015 by dabba Quote Link to comment Share on other sites More sharing options...
malcolm Posted August 14, 2015 Author Report Share Posted August 14, 2015 Thanks for the advice. How tight should the chain be. Quote Link to comment Share on other sites More sharing options...
dabba Posted August 14, 2015 Report Share Posted August 14, 2015 About 20mm (or a finger) from the top of the chain tensioner slipper pad to the underside of the swinging arm. Quote Link to comment Share on other sites More sharing options...
