Should I Torque The Bolts After Adjusting The Forks/front Wheel?
thesaint
Since the front wheel was a little "off" to one side i adjusted the forks by loosen the clamp triple top yoke and the clamp lower triple lower yoke and adjusted the front wheel.
After doing this the front wheel is straight as it should be  :thumbup:
Should i torque the bolts and if so how much torque?
Yes, I would torque the fork clamp pinch bolts. The spec I have is 8 ft/lbs for the top bolts and 10 ft/lbs for the lower ones. That is for my pro but should be the same if yours has 6mm threaded bolts.
And you would also have loosened and re-tightened the fork brace (mudguard bracket). 6 to 7 ft/lbs for those.
Chris.
Thanks a lot for helping me out here with this  :thumbup:
I will torque the bolts according to the specs provided by aussiechris  :thumbup:
I did bounce the fork up and down but I will check the pinch bolts as lineaway suggested  :thumbup:
