Transmission Woes Again?
lineaway
  • 2 weeks later...
Ditto
2015 125 throw its chain as my son was riding between sections (probably on song at the time!).
Lost a total of 5 teeth across two gears, parts on order.
Have ordered gaskets but the original base gasket is a rubbery construction not paper, is this gasket designed to be reused?
The original base gasket seems to be a better material, will it be ok to reuse it?
Not worth the hassle or risk for a few extra quid, if it leaks you will have to remove the engine, strip and rebuild it again!
Edited by suzuki250
