alta Posted August 31, 2015 Report Share Posted August 31, 2015 Disregarding an aftermarket frame, what mods have you done to your cub in order to improve competitiveness? Quote Link to comment Share on other sites More sharing options...
alta Posted September 4, 2015 Author Report Share Posted September 4, 2015 Clearly nobody has done anything to theirs!!! So this is what I've done to mine: Frame geometry is standard. Armac yokes. Armac tank, with fabricated brace under tank. Tank mounted as low as possible. Home made plastic seat with vinyl covering. Armac exhaust system. 35mm forks from an air cooled Beta hidden in Triumph heavyweight sliders. Billet front hub. Subframe loop removed. Subframe narrowed. Footrest to handlebar relationship as 08 Scorpa. Rockshocks. Chaintube. Home made chain tensioner. Alloy rear spindle and snail cams. Home made stainless brake pedal. Alloy swinging arm spindle with silentbloc bushes. Motor is 199cc with R cam. Alloy clutch pressure plate. Longer clutch actuating arm. Low second and high top gears. Primary chain tensioner. Gearbox sprocket access cover. Crankcase modified to prevent mud build up around gearbox sprocket. Electrex electronic ignition. Cheap "Mikuni" carb form Ebay, with foam filter. Home made oil tank with sensible capacity. Wet weight is 87kg. Your comments Gentlemen please! 1 Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted September 4, 2015 Report Share Posted September 4, 2015 Wow, did you keep any of the original cub? Quote Link to comment Share on other sites More sharing options...
aawil Posted September 4, 2015 Report Share Posted September 4, 2015 it sounds like you have a well sorted triumph cub but why oh why is it in the pre 65 bit of the forum. will. Quote Link to comment Share on other sites More sharing options...
bashplate Posted September 5, 2015 Report Share Posted September 5, 2015 pictures please Quote Link to comment Share on other sites More sharing options...
alta Posted September 6, 2015 Author Report Share Posted September 6, 2015 It's in the Pre 65 forum for two reasons, one is to provoke comment and hopefully gain some hints and tips, two is because it is probably more "pre 65" than most cubs you see! I freely admit that it's a cheat but is mainly ridden against modern bikes on the "B" route. Maybe we need a new category in the Forums called "Britshocks"!. I forgot to say that it also has alloy rims but I have retained the std cub rear hub which hasn't been widened although it does have an alloy brakeplate. 2 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted September 7, 2015 Report Share Posted September 7, 2015 I think you might have got more response initially with a different heading. I read the heading a different way to what you seem to have intended people to read it, and didn't even open the posting until you replied to yourself 1 Quote Link to comment Share on other sites More sharing options...
alta Posted September 7, 2015 Author Report Share Posted September 7, 2015 Yes, you're probably right! Still nobody letting on as to what they've done to theirs though! Quote Link to comment Share on other sites More sharing options...
wallo Posted September 8, 2015 Report Share Posted September 8, 2015 I took the alternative approach. I bought a Yam twinshock and put an alloy Cub tank on it, a few Triumph stickers and Bob's your uncle. I used some liquid metal to fill in the Yamaha logo on the crank cases, I get a few comments, but that's down to it being a 2-stroke, all I say is it's the 2-stroke cousin of the Cub a bit like the Bantam to the C15 :-) I'll post some pictures soon. 2 Quote Link to comment Share on other sites More sharing options...
charlie prescott Posted September 9, 2015 Report Share Posted September 9, 2015 Hi Guy's Hi Wallo, How is your "Bantam" running?? Has it done any modifications?? Love the picture of it you sent me, may post it on my site!! Regards Charlie. Quote Link to comment Share on other sites More sharing options...
alta Posted September 9, 2015 Author Report Share Posted September 9, 2015 Ah well, at least my "mostly cub" is tax and mot exempt!......... Quote Link to comment Share on other sites More sharing options...
trialsrfun Posted September 12, 2015 Report Share Posted September 12, 2015 Riding a bike which you have built and developed yourself is so much more satisfying than just buying one. 2 Quote Link to comment Share on other sites More sharing options...
wallo Posted September 17, 2015 Report Share Posted September 17, 2015 ........ and a lot more expensive :-) Quote Link to comment Share on other sites More sharing options...
bashplate Posted September 18, 2015 Report Share Posted September 18, 2015 still waiting patiently for pictures of this marvelous cub!!!! Quote Link to comment Share on other sites More sharing options...
alta Posted September 18, 2015 Author Report Share Posted September 18, 2015 Have to agree with both trialsrfun and wallo! It's not just about riding the thing. It's the tinkering, developing, wondering what to do next, trying different things that sometimes improve performance and sometimes don't and yes it can be expensive! That's why I try to make as many bits and pieces as I can. As for pictures, I'll take and post some shortly. Incidentally, there is a nearly full page pic of my dad riding it when it still had all the steel bits in a Classic Bike magazine of I think 1982 vintage. I seem to remember the front cover featured John Surtees' Vincent Grey Flash. 3 Quote Link to comment Share on other sites More sharing options...
