2stroke4stroke Posted August 31, 2015 Report Share Posted August 31, 2015 (edited) Not the usual question, but having recently acquired the bike I need to ask. The bike starts first kick (after the priming kick) every time from cold. When hot it sometimes starts first kick and sometimes needs two or three kicks. I know about the tickover thing and keeping the throttle shut and having had a chance to adjust it at the last trial ithe tickover is now, I would say, a bit faster than others and certainly fast enough. I've seen other folk start theirs with a casual kick halfway through the swing but mine needs the very longest swing you can get. If an adjustment was out then I would expect it at least to be consistent and either always a good or bad starter rather than varying at random. Does anyone have any advice or is it just something I'l have to live with? I've spoken to about ten owners and, interestingly, despite the alleged criticality of the tickover speed, not one of them knew what speed their tickover was set to, never having used a revcounter to check. I normally use Silkolene but they tell me they don't do a suitable 10/40 for the motor, apparently the Mont uses a different spec; what do most people use in the motor, as opposed to the clutch? Edited August 31, 2015 by 2stroke4stroke 1 Quote Link to comment Share on other sites More sharing options...
the addict Posted August 31, 2015 Report Share Posted August 31, 2015 I'm using Putoline and Elf HTX in the gearbox. Make sure there's a little slack in the throttle cable and check the valve clearance's if need be. Mine is the same when hot but to be honest its never bothered me. Quote Link to comment Share on other sites More sharing options...
lineaway Posted September 1, 2015 Report Share Posted September 1, 2015 I do not own a 4RT, but I ride them frequently. (My boss has five of them and several on order) Usually when hot and they don`t start, is because I kick them like a two stroke. Just, slow and gentle and for whatever reason they fire right up! Quote Link to comment Share on other sites More sharing options...
guys Posted September 1, 2015 Report Share Posted September 1, 2015 Engine oil Castrol Power 1 I suppose by priming kick you mean "throttle reset"? A slow kick with the throttle fully open. Changed the spark plug yet? And make sure the headlight is off if you have one. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted September 1, 2015 Author Report Share Posted September 1, 2015 No, I mean the kick to charge the ECU first thing but it's OK when cold anyway. Plug is new and I use the slow and gentle technique. Thanks. As I say it does need the longest swing possible, a few degrees less and it's not keen, I don't know if that indicates anything. Quote Link to comment Share on other sites More sharing options...
jrsunt Posted September 1, 2015 Report Share Posted September 1, 2015 check valve clearances. Too tight and they are a pig to start 1 Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted September 1, 2015 Report Share Posted September 1, 2015 (edited) Check valves and maybe try new sparkplug? Sparkplugs can be nasty things (offcoarse especially with 2strokes but also 4t) Edited September 1, 2015 by crazybond700 Quote Link to comment Share on other sites More sharing options...
ruffmutt Posted September 1, 2015 Report Share Posted September 1, 2015 It,s knackered, I,ll give you tenner for it! 1 Quote Link to comment Share on other sites More sharing options...
guys Posted September 2, 2015 Report Share Posted September 2, 2015 This actually belongs here (thanks to The Addict) 1 Quote Link to comment Share on other sites More sharing options...
wakka Posted September 2, 2015 Report Share Posted September 2, 2015 nice' makes me like my bikes even more 1 Quote Link to comment Share on other sites More sharing options...
