Clutch Lighting
tom675
My uncle has a 2011 ossa 280, the clutch is very heavy and really spoils the bike, i previously had the same year bike and mine was lovely and light, same as other bikes. Is there a way of lightening it, maybe removing a couple of springs?
If yours was the same bike with a noticeably lighter set up then perhaps it would be worth checking out what you already have ? Perhaps the master or slave cylinders are partially seized, wrong oil used or has the hydraulic oil been changed from original spec ?
I do not think there should be much difference between bikes of a similar build spec so I would look for what may have changed first before you try to modify what you have.
