sammyd173 Posted September 4, 2015 Author Report Share Posted September 4, 2015 So there are telltale signs of coolant dried on the back of the cylinder. Pulled head and it was caked with white crud. The rubber gaskets look fine. But the fan is turning slow enough where I can see the insides of the blades turning. It is pulling hot air out but it's more of a waft. I'm wondering if that means the fan is bad or that it's not getting enough current, any ideas? Quote Link to comment Share on other sites More sharing options...
sectionone Posted September 4, 2015 Report Share Posted September 4, 2015 My 07 with a ducati ignition had a fast fan speed when new and it got slower over the years. You probably don't have enough current. Hook up a 12 volt battery and compare speeds. Quote Link to comment Share on other sites More sharing options...
faussy Posted September 5, 2015 Report Share Posted September 5, 2015 I think you are describing something slightly different, but when the thermostats are on the way out they cause the fan to stutter and come on for brief periods at a time. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted September 5, 2015 Report Share Posted September 5, 2015 omit thermostat, ie leave fan on all time if symptoms are the sme coolant is too low or not circulating. Pump gas or race gas has little to do with whether the fan or coolant are doing the first job. Quote Link to comment Share on other sites More sharing options...
sammyd173 Posted September 18, 2015 Author Report Share Posted September 18, 2015 Problem solved - the rectifier was bad and made the fan run too slowly. Took a chance and bolted a new one in and that was it! Thanks all! 1 Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted September 18, 2015 Report Share Posted September 18, 2015 Nice sorted out! Quote Link to comment Share on other sites More sharing options...
sammyd173 Posted September 19, 2015 Author Report Share Posted September 19, 2015 Thanks! Didn't want this to be one of those threads where you never hear the answer to what the problem was! Quote Link to comment Share on other sites More sharing options...
motovita Posted September 19, 2015 Report Share Posted September 19, 2015 Problem solved - the rectifier was bad and made the fan run too slowly. Took a chance and bolted a new one in and that was it! Thanks all! I was just going to post that that's what happened to me on an older Gas Gas. It was frustrating because I couldn't see that the fan was turning slowly, everything seemed to be working normally until it overheated. Quote Link to comment Share on other sites More sharing options...
