vegas3416 Posted September 6, 2015 Report Share Posted September 6, 2015 I have a 2013 Raga with tech forks installed and am told the front hub that goes with the tech forks does not require a spacer on the front hub but the hubs I keep ordering all seem to require the spacer. I've seen pics of the Ossa with tech forks and it does not use the spacer. So I know what I've been told is correct but need to know if guys are using a stock hub with the tech forks and you are using a spacer is the wheel offset a little to get the wheel to sit in the middle between the forks and the other question is if you have an Ossa with tech forks could you measure the front hub so I can see how much different the hub is from mine and to try and see what offsets are different to determine if it will be just better to find the correct hub vs having to use the spacer. Any help you guys can give would be much appreciated. Quote Link to comment Share on other sites More sharing options...
vegas3416 Posted September 6, 2015 Author Report Share Posted September 6, 2015 Nobody? Anyone have tech forks on their ride? Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted September 6, 2015 Report Share Posted September 6, 2015 yes washer like spacer rhs viewed from front Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted September 6, 2015 Report Share Posted September 6, 2015 at least there is on mine 2013 raga racing Quote Link to comment Share on other sites More sharing options...
vegas3416 Posted September 6, 2015 Author Report Share Posted September 6, 2015 And you're running tech forks? Also is your front wheel offset a little to the disk side to get it to sit in the middle of your forks Quote Link to comment Share on other sites More sharing options...
vegas3416 Posted September 6, 2015 Author Report Share Posted September 6, 2015 And spacer just on axle shaft or also behind disk Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted September 7, 2015 Report Share Posted September 7, 2015 (edited) disk has a spacer behind and that matches the spacer in thickness. Think the hub is a standard gg one and they spaced it to fit new forks. Im not "running " tech forks thats how it comes. would take a photo but wheels in truers workshop will do when its back. Edited September 7, 2015 by nigel dabster Quote Link to comment Share on other sites More sharing options...
lowbrow Posted September 7, 2015 Report Share Posted September 7, 2015 I think you'll find the spacer is actually a sleeve to reduce the ID of the standard bearings to the smaller diameter of the Tech wheel spindle. On my Jotagas the sleeve is installed from the opposite side to the disc; there's nothing to space the disc side of the hub away from the fork leg and the disc and calliper line up perfectly. So provided your disc and calliper are in alignment surely it's just a matter of tweaking a few nipples if your rim isn't central? Quote Link to comment Share on other sites More sharing options...
