Beta Rev3 Big End ?
tonyp
Hi,
I took the head/barrel off my 2004 Rev3 today......
- No discernible up/down movement in small end or big end.
- But I could rock the conrod to & fro a bit...
this wasn't just sideways movement on the crankpin
Do you think the big end is worn ?
How tolerant are Rev3's to a bit of wear ?
I'm OK running with a worn engine, just wondered if it's going to blow-up big time in the near future?
TonyP.
For peace of mind I would get a second opinion from an experienced mechanic or measure con rod movement by a specified method. Depends how much use your bike has had and what sort of use / care but 2004 big end could be getting a bit tired. Any doubt and it may be better to replace it and the mains. Even if big end does not fail suddenly bits of bearing cage can break off and wreck piston, barrel and head.
