A747 Oil
adam1
hi all
I have been using this in my 315r with good results and I love the smell...
I have just bought a 2011 beta evo 250 which has Been run on putoline TT trials.
Is there any benefits to running either 2 stroke oil and if the castrol a747 was the preferred what would I need to do to start using this?
Thanks
hi all
Thanks
To the best of my memory...Castrol A747 is/was a synthetic based oil with some castor elements (hence the Castrol "R" smell). It was intended for highly stressed 2 stroke road race engines (Yam TZ, Honda RS etc) and was pretty pricey and also had a shelf life, I think. It had a "sister" oil for off-road and less demanding applications that was Castrol A545 that was then renamed something else... John Shirt Snr used to SWEAR by it when he was involved with Yam TY monos..Most good two stroke oils will serve well in trials applications IMO
Full or semi synthetic best for trials.
The castor based "synthetics" like A545 and A747 only have an advantage at the extreme limits of lubrication.
At the limit non castor oils thing out and evaporate of meaning no lubrication.
At this limit castor oils thicken and char preventing metal to meta contact, or at least trying to
