Sag ?
lpd
I decided it was time to change the fork fluid on the bike. Drained the forks and to my surprise 250cc's in the damping and 325cc's in the rebound :lol: There are no visible leaks in the seals ect. not sure about the difference. Filled up both forks to factory specs (I use 5w but I'm a light rider 150lbs) and I noticed that the bike sags in the front end under its own weight about 3/4 of an inch. With me on the bike it sage a little over 2 inchs. Should the front sag under the weight of the bike or should I put a little more preload on the springs?
Thanks in advance....
the new gasser crasher
Thanks,
I went out for a ride today and noticed that the front is plowing as I ride (took a nice spill over the bars on a sharp downhill turn). I'm going to raise them maybe a 1/4 inch and see how much of a difference it makes.
