Sherco 125 2012, 13, 14 Or 15. Known Issues?
stpauls
15 has been the best year yet for the sherco 125, had no problems on it other than the jet clogging in the carb which was down to dirty fuel. the gear box is very positive and never had any jumps or issues, on the 14 and 15 the quality is alot better than previous bikes. ill be getting a 16 soon so pm if your interested in mine, its mint, im down south.
Our 2013 had a few problems. One of them caused a crank main bearing failure. The factory had fitted main bearings with only one seal facing inward. This left the outside of the bearing open and with no lubrication.
The Formula brand brakes have been very troublesome. Best to buy a later model with AJP brakes.
Watch out for a seized swingarm bolt. Make sure you check it moves before paying any money.. Get a photo if you cant see the bike..
