mcman56 Posted September 28, 2015 Report Share Posted September 28, 2015 How do you get the CDI out of a 2008 Rev 3? It is jammed up in the front of the frame and it is hard to see. Does it jsut slide out of a sleeve? What od you have to remove to get access? Quote Link to comment Share on other sites More sharing options...
worldtrialchamp Posted October 10, 2015 Report Share Posted October 10, 2015 lots of wires and stuff makes access difficult. I know it's more time consuming but I find any work in that area is easy once radiator is out....personal preference.. the CDI sits in a rubber sleeve which after time may bond itself to the CDI plastic case..... if you remove the o ring around the fuel filler neck, and remove the plastic tank trim, then radiator cap, the access is not too bad for removing CDI through the frame top.... still prefer to remove radiator, gives me a chance to inspect everything, clean up the area and ensure the routing of wires etc won't pinch when steering goes lock to lock Quote Link to comment Share on other sites More sharing options...
mcman56 Posted February 12, 2018 Author Report Share Posted February 12, 2018 I was able to get it out through the top. However, I could not get it started in the sleeve to put it back. I pulled up this old posting and ended up pulling the radiator to reinstall. Thanks Quote Link to comment Share on other sites More sharing options...
