ajock Posted October 1, 2015 Report Share Posted October 1, 2015 Renewing bearings on standard ty wheels, old ones had inner seal removed and grease packed from side to side. New bearings are fully sealed. Should i remove inner seal and grease or leave them sealed and assemble dry. p.s. fitting with new alloy spacer. Thanks in advance. A Quote Link to comment Share on other sites More sharing options...
tony27 Posted October 1, 2015 Report Share Posted October 1, 2015 You can remove the inner seal with a very thin screwdriver or pick & pack more grease into the bearing before refitting the seal if you feel it's needed otherwise just fit the bearings with both seals still in place 1 Quote Link to comment Share on other sites More sharing options...
trialsrfun Posted October 1, 2015 Report Share Posted October 1, 2015 Keeping the outer seal that covers the bearing is more important as well as NOT squirting a jet was at the hub area. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted October 1, 2015 Report Share Posted October 1, 2015 I've seldom opened a bearing and found an adequate amount of grease. I refill with waterproof grease. Quote Link to comment Share on other sites More sharing options...
