Montesa 309 Gearbox & Fork Oil
94chas
Hi all
      just bought an old 309 mont been stood many years would like to know the gearbox oil capacity and type,also same for the forks.
        Going to drain the old fuel & clean out the carb see if it will run,then I,ll have some more questions for you guys.
                    Thanks in advance
                        Regards Chas
Hi,
The 310 is very similar to the 309 as regards quantities oil wise, the 310 manual suggests 750ml (10w/30 Gearbox, and 240ml per leg on the Forks), the 309 manual is hard to come by as you may have found!!!
Hope this helps in the meantime,
Cheers,
facebook.com/groups/hardtofindtrialsandaircooledmono/
Thanks for reply will get the gearbox oil changed.Your suspension is very different to mine is the capacity the same.Any idea of viscosity.
                Many thanks
                  Regards Chas
